RCU Forums - View Single Post - Igniter! Error Code
Old 03-24-2025 | 06:33 AM
MrSwaggins1738
Post Igniter! Error Code
Does anyone know what potential problems are associated with this error code? It shows up when I try to run it and displays as the most recent off condition when turning on the ECU the next time. The burner test runs normally with the voltage and temperature increasinng the longer you run it. I've run every other potential test and everything seems to be working fine. Unfortunately I can't seem to find any other potential source for the error code so any input would be helpful. Thanks!
