RCU Forums - View Single Post - My Advanced Realistic Humanoid Robots Project
Old 04-12-2025 | 07:29 AM
Artbyrobot
Ok so I did a big refactor of my pulleys and ran a test again and it still is not working. The first set of archimedes pulleys tops out and can't move anymore while the finger still hasn't moved. This is because of slack in the lines. I did not calculate slack in the lines into my calculations at all and am shocked by how much there is... Rather than do a major new overhaul with new math and new draw distances on every pulley AGAIN, I'm going to just drop the final pulley of the system so instead of 44:1 it will be 22:1 now. While we cut half the grip strength with this move, this might be okay after all. It still gives us 20lb of of burst grip strength I believe and 11lb of casual easy sustainable grip strength. Most common tasks should only require 8lb of grip strength anyways for a single joint tops. Because remember, I'm not doing a single motor for all 3 finger joints but one motor per joint which helps alot in the strength department and control department. So anyways, this hack I think is okay also because it hit me lately that I highly doubt I'd use the full beast mode burst strength of a 44:1 downgear anyways. I'd be too worried about the wear and tear on the fishing lines and pulleys and maintenance times getting too short between maintenance overhauls if the robot is using that level of grip strength for tasks. In reality, I am now imagining I will only let the robot do VERY minimal strength stuff to reduce the maintenance to a minimum. Like sewing, cutting, and delicately picking up small loads. I will treat it like it has the strength of my 4 year old just to baby it and make it last longer between repairs. Kind of like having a old beater car you don't trust and never throttling the engine hard but just gradually easing on the gas pedal to avoid blowing a gasket so to speak and avoid a trip to the mechanic. So that said I think 22:1 might actually be okay. And with that final pulley out of the way, I'll have WAY more than enough draw distance to bend the finger 90 degrees and account for string slack AND account for string stretch over time without any issues at all. Much better. Not to mention we do pick up speed this way and that might be a VERY nice feature when all is said and done. A faster moving finger can speed up its work I think. Like notice how 3d printers go way faster and that speeds up prints. So speed might be king over grip strength in the end perhaps. It's a tradeoff.
Another update is I realized I can wind a second very fine 0.08mm fishing line on the output portion of the winch in place pulley mounted next to the motor and this second line coming off that pulley will be attached to a tension spring consisting of a bracelet jewelery making cord for jewelry for kids. This line will maintain tension on that winch in place pulley and the motor output shaft at all times to prevent derailments. The metal tension spring that extends the finger will then have the help it needs to keep the whole system taught. That's the plan anyways. The runout of this line will need to be 12.48" of tensioned draw. To achieve that I need a length of this cord of about 15" I think which stretches to 27.48" at full extension. This would occur each time the motor causes the grasping actuation and it would be playing tug of war with the motor so that when motor relaxes or reverses direction, the winch in place is remaining tautly in opposition.
