RCU Forums - View Single Post - YS DZ200cdi
Thread: YS DZ200cdi
Old 04-28-2025 | 02:31 AM
  #377
bjr_93tz
Originally Posted by allenpl
Agree re sloppy barrel/throttle body fits and I followed previous posts and your own by fitting O rings to the barrel.
Seemingly you've abandoned that system - ??
Using KL198 oil ??
I mix (by weight - saves a lot of messing about) 14% KL200 and 23% nitromethane - also suits DZ115.
Yes, I gave up on modifying the original. I believe the barrel to body clearance was just too large and was swamping the metering action of the tapered slot in the barrel against the fuel port in the bore at the low/idle position.
I'm a decades long cool power user in a variety of engines but picked up a 2nd hand nitro heli (OS105HZ-R) that came with a few extra litres of fuel that was mixed with Klotz KL-198. To cut a long story short, I replaced all the engine internals at 32litres, then zeroed the "clock" and using mainly coolpower blue oil and sometimes purple, changed the rear bearing at 50 litres, and then both bearings and ring at 80 litres. I then swapped to using KL-198 oil and I'm now at 190 litres (110 litres on the same bearings and ring) and I still feel no need to change the bearings. I feel that in that engine, the way I use it, I suffer less bearing rusting between flying sessions and I'm keen to run this DZ200cdi with it to see if I get less rusting inside with it as well. Running wise, the OS 105HZ-R doesn't seem to care what oil it's turning into smoke and it's fuel consumption is about 65cc/minute. I've never tried the KL-200 but the SDS says it's about double the viscosity, 23.3cSt @100degC vs 11.1cSt @ 100degC for the KL-198.
I use scales and mix using weight as well for convenience reasons. The specific gravity of the Klotz is fractionally greater than 1, but close enough for me to call it 1. The specific gravity of cool power is/was about 0.98.
Got 5 x 13 minute flights in this afternoon in very blowy (25km/hr) conditions. Didn't touch the main needle but tweaked the pump 1/8turn leaner for the last two flights. Currently running 30% nitro, 12%oil and 58% methanol and will drop that oil back to 10% oil after a few hours. Just happy to be flying a decent fixed wing plane again..
