RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 05-06-2025 | 12:39 PM
  #2542
Fxdr
Default 3d printed housing for solenoid
Originally Posted by Cat 1
SO.... This little project took a lot more fiddling than one would think but I have finally succeeded at 3D printing a Solenoid housing. Made in Nylon (PA) for fuel resistance the Print parameters needed much tweaking to get a liquid tight seal and tolerances for the housing bore - But its now repeatable on higher end printers I would think.
This is just an offshoot of a bigger trial to print an "all in one" pulse pump and fuel control "block" - getting close on that one too but fighting getting the unit to seal up tight. Have a working unit but its still a little leaky...
Do you think a sla resin should be gasoline resistant in Time it should be more accurate than fdm in nylon petg asa or abs, i have sla and fdm printers i should try your STL but personally, trying to maximise experience of conversion as we use to hear by now, i'm using brutus1967's aluminium housing.
