RCU Forums - View Single Post - Direct servo connection to control surface question
Old 11-16-2003 | 05:39 PM
mr_matt's Avatar
mr_matt
My Feedback: (10)
Default RE: Direct servo connection to control surface question
If you can get a servo that close to the moveable surface, can't you use a regular torque rod system?
I suppose your approach could work, but you will loose a lot of the servo's torque.
THe servo is design to rotate 90 degrees total, give or take. I would figure on a scale jet, you are not going to want more than 10 or 12 degrees in each direction (and even that sounds like a lot). So that would be 20 -24 degrees total.
So the effective torque is say (24/90) times less, only 26% of the torque you would get if you could set up the linkage to use all of the servo's throw.
PS your slop will be a lot worse too.
