RCU Forums - View Single Post - CARF Bolt! Build thread
Old 07-14-2025 | 02:19 PM
  #192
kchong
Originally Posted by Dave Wilshere
The harder I try to get free time...the more people visit me! Today has achieved little, but the last real construction was finished last night when I fitted the nose gear servo plug & socket. I mounted the plug in the fuselage and socket in the nose. The plug was mounted first and two strips of masking tape laid back to back were tasked together with spray mount. The position of the plug was cut through both layers, then the nose installed. Separating the two layers allowed the tape to stick to the nose and once removed the exact position of the socket was cut...lined up first time 🙂
Hi, does the servo plug give you any trouble over time, would you recommend to install the same plug or just manually insert the servo cable to fuselage?
