Originally Posted by
kchong
Hi, does the servo plug give you any trouble over time, would you recommend to install the same plug or just manually insert the servo cable to fuselage?
I have mounted a MULTIPLEX plug on the nose, socket on the fuse, same location as the yellow AMASS plug shown. This gives me possibilities for a beacon light on on top just behind where the clear canopy glass ends. Just slide on the nose to the fuse, works great 👍
