RCU Forums - View Single Post - CARF Bolt! Build thread
Old 07-15-2025 | 08:58 PM
  #194
Dave Wilshere
Originally Posted by kchong
Hi, does the servo plug give you any trouble over time, would you recommend to install the same plug or just manually insert the servo cable to fuselage?
Plug has worked perfectly over hundreds of cycles. As long as you mount it securely you won’t have an issue. This is a Powerbox One4One lead
Dave
