RCU Forums - View Single Post - BJCraft Bipes Quick Release Struts
Old 08-07-2025 | 06:58 AM
J-P
Default BJCraft Bipes Quick Release Struts
Upgrading BJCraft Bipes with quick release struts
The advantage is you no longer have to use screws
They can be ordered as a kit or completed from BJ
I had a kit of the standard BJ Leader G struts and decide to use them in conjunction with a FLIGHT HOBBY part used for the TOP STAGE BIP
So it’s a lot of work, but I think it worth it
The center part of the strut must be modified to integrate the quick release mechanism
Adjacent plywood holes are filled with balsa
The small tube is glue in place and receive the 1,7 mm pin
The small tube is glued in place and receive the 1,7 mm pin
The small tube is secure to the center plywood par by a 2?5 mm glass cloth epoxied
The small tube is secured to the center plywood par by a 25 grams glass cloth epoxied
Struts are painted
Struts are painted
Original slots are filled with a 2 mm plywood piece epoxied in place
The Hobby Flight part is screw in the wing with the two 2 mm screws coming with the parts, plus a 3 mm screw using the factory drilled hole    as well as perfect location of the strut
The Hobby Flight part is screw in the wing with the two 2 mm screws coming with the parts, plus a 3 mm screw using the factory drilled hole as well as a perfect location of the strut
You can rounded the parts in order to have the struts remaining on one wing, the upper one for example, held in place with a small velcro
Parts can be rounded in order to have the struts remaining on one wing, the upper one for example, held in place with a small velcro
wattsup (08-27-2025)
