Originally Posted by
camss69
Lands absolutely perfect, super easy.
I’m only using the main tanks for fuel, timer is set to 5:45 but I could go 6 easy. Running a 180 G4 in mine. Since my ECU battery is so small (2200) I can only get 4 flights and have some lead in the nose. I need to get a bigger ECU batt and lose some lead. But even with dual 3250 lipos on the receiver after 4 flights they are down to 57% as well. This plane seems to use a lot of battery. I suspect because the surfaces aren’t the most free moving and the servos are working hard.
I run the same RX batts in my Diablo and can get 6 flights easy and be around 60%.
why don't you jump upto a couple of 5000 mah lipos.
