RCU Forums - View Single Post - Flaps not binding to transmitter
Old 11-21-2025 | 05:31 AM
A. J. Clark's Avatar
A. J. Clark
The nomenclature on you receiver shows the negative pin is on the outer edge of receiver, positive pin is middle pin, and signal is on inner pin. Plugs look like there plug in with signal wire on outside pin and negative wire on inside pin. Try turning connector plug in opposite direction.
CaptRogerOver (11-24-2025)
