RCU Forums - View Single Post - Problem with Fuel flow!!!
Old 11-21-2025 | 06:06 AM
A. J. Clark's Avatar
A. J. Clark
I had a similar problem or at least I thought. I checked everything out and never found a problem. The turbine ran fine. In your case access being a problem I would break the line to the pump. Run a line outside the air frame and see if the fuel will siphon out. If you get good flow your probably OK there.
