If there is indeed a problem with the clutch, check the spring(s). If you turn the engine over and the truck wants to move, one or more springs is likely broken causing a shoe to kick out and grab. Lack of endplay could cause this to happen too, but it would have to be crazy tight for that to happen. A bad bearing would be more likely to cause issue versus lack of endplay.
