Originally Posted by Tomcoleman;[url=tel:12828908
12828908[/url]]Just building my diablo
is it normal to trim the servo horn slots?
I had to dremel out some of of the servo holders to get servos in and on the tailrons/elevators I had to dremel out to get the servos in
also had to cut/trim control rods to get correct length
not an issue just manual mentions not of this …?
Yes, normal to open up the slots for the servo arms.
Yes, depending on the servo you use, you may need to open up the servo pockets slightly.
Yes, cut your linkages to the correct length.
