meh scrapping the plow on the deuce and a half.
due to the bumper being higher then the SCX 10 I would need to make a new plow blade, and change even more of the angles, and then there is also how the chinese no-name MG servo I used stripped a gear... MG in that servo stood for Metal Gear as I took it apart and found exactly one Metal Gear in it(the output) the rest were all a light grey plastic which sorta looked metal in the dark smoke tinted semi transparent housing. And the way I swapped to a linkage to try and make the plow work cause it to die... even though the plow wasn't even on the ground it was dangling off a table while I was trying to adjust my radio.
So just gonna throw the plow it back on the SCX 10 with the setup I know that works
