A bit more testing today. The magnum got a bigger prop and still preformed like an electric motor - this one seems perfect on the stand.
Just to prove out the theory I mounted up an old and tired Saito .40 and in short order had it running fairly well also with very similar needs for auxiliary bleed curve. This one was a little bit tricky with the interaction between the high and low needles but got it relatively running ok relatively quickly.
