RCU Forums - View Single Post - RC P=51 “Gunfighter" ARF $3000
Old 03-01-2026 | 05:04 PM
DCGayhart
My Feedback: (22)
Default RC P=51 “Gunfighter" ARF $3000
Top RC P=51 “Gunfighter" ARF is a remarkable replica of America's favorite warbird. The airframe is constructed with full composite Sandwich Technology" incorporating the lightest aircraft ever introduced at this price point.
Specifications:
Wingspan: 89 in (2260 mm)
Length: 77.4 in (1965 mm)
Weight: 24.5 lbs. (11 kg)
Wing area: 1397 sq in. (90.2 dm2)
Features
Full composite construction (no iron on covering)
Pre-painted surfaces with clear coat and applied decals
True scale outline with accurate details
Scale, painted, full-depth cockpit
Scale exhaust
Detachable main wing and tailplane for easy transportation
Removable fuselage hatch for easy interior access
Aluminum wing rods
Working landing gear doors front and rear
Scale antenna is detachable for easy safe transport.
Working scale flaps take the fear out of landing approaches, providing slower, smoother landings.​
Scale exhaust outlets make this warbird so real you can almost smell the aviation gas.
Scale TRCM main and tail electric retracts, with wheels are included!.
New DLE 55RA rear exhaust with muffler is installed with Mejzlik 23x8 Carbon Fiber Prop.
2-JR DS821HV servos control Throttle and Tailwheel steering.
4-MKS HV1220 servos control Ailerons and Elevators.
4-Spektrum H7040HV servos control Flaps and Main Gear Doors.
1-MKS HV777 servo controls the Rudder.
Airplane is completely built with servos and engine installed. Engine has been test run with spinner to test balance.
This airplane has never been test flown! You can install your receiver, test all the controls and be the first to fly it!
If you total up all that’s included with my Top RC Model P-51D it comes to 0ver $4400.00
I'm asking $3000 OBO.
ID:	2275201   Click image for larger version
ID:	2275202   Click image for larger version
ID:	2275203   Click image for larger version
ID:	2275204   Click image for larger version
ID:	2275205   Click image for larger version
ID:	2275206   Click image for larger version
ID:	2275207   Click image for larger version
