hi,
I find out the back motor is controlled by a 10 pins
LB1640 as seen on the this picture,
i tested the motor with a 9v battery and its ok, (the wire blue and white are the + and - of the motor)
so the problem is the LB1640 does not get what its need on IN1 or IN2
on the pics below i inverted the picture on the bottom to match the circuit on the top and try to find out the componants before IN1 and IN2 on the LB1640
