Which Mode???
Hi All
I've just built a LT40 and (heh heh) fitted a 61 size Engine. because of the bigger engine, I had to replace the engine mount to a stronger one, and added bit more support to the firewall, and changed the undercarrige too (was a bit feeble anyway), plus a 12 oz tank had to go in (piccys will follow for you all to see soon). Fitting the new undercarrige (Which looks good), the 11 inch prop is now 2 inches from the ground. the hight of my plane looks fine, also because my plane is now front heavy I had move the radio to the back to ballance it out.
Now to my problem, I don't know which mode to use here in the USA, Ailerons on left stick or rudder???
Thanks....
