RCU Forums - View Single Post - K&B motor issue
Thread: K&B motor issue
Old 03-26-2026 | 11:06 AM
carlgrover
If the engine runs with the glo ignitor on then dies when you take it off, you might have a bad plug OR the needle valves are grossly out of adjustment. Try adjusting the high speed needle valve with the ignitor on and engine running full throttle until it runs well. Then disconnect the glo ignitor. If it still dies, the plug is bad.
carl
