RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 03-28-2026 | 05:55 AM
  #2888
Bernett
Cat1
I was wondering if you have a 2 stroke engine with an air bleed carb that you could try your air bleed valve on it to see if you achieve a satisfactory result. I still have to make and set up an air bleed valve before I can try it. If you can do that I would appreciate it. Thanks
