RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 05-15-2026 | 05:49 AM
  #3029
Cat 1's Avatar
Cat 1
Hmmmmm.. There we go. I like the look of that valve. The curve i get could be "flattened" by using a valve such as this, and would have the possibility of fine enough control at the bottom end to do the fine adjustment needed for compensation.
I don't know if i can do it with my Graupner, but can a OpenTX system measure temperature and pressure and adjust output to an air bleed valve?
