RCU Forums - View Single Post - Beginner Pattern Plane
Old 11-17-2003 | 09:01 AM
PatternPilot's Avatar
PatternPilot
My Feedback: (58)
Default RE: Beginner Pattern Plane
The Viper 91 is also a good choice, It will use the OS91 fx or a YS 91/110. The plane is hand crafted and is a great piece of woodworking.. The plane is ready to cover with a little work to finish it up. There is also a carbon fiber options for it.. the weight is around 8lbs and mine uses the OS 91FX swinging a APC 15x10 prop with tank on cg and ONLY pipe pressure, no header tank or pump.. The plane is great for starting out and will move you thru the diffrent classes, Tech support is a phone call away and there is also a Viper in the 2 meter size.You can't beat the price for this handcrafted plane...
scott
Having some problems uploading photos, if you would like to see some send me your email address and I'll send some photos...
