RE: Direct servo connection to control surface question
Hi Doug
Your correct thinking about it, the resolution will be an issue, I guess the pattern guys on the big stuff use it on rudder only where more movement is needed.
I will have to have another look at the rads approach and try a set to see how it works for myself rather than others views about the play. Like most things with this hobby the better the build the better the flying
Thanks for your views
Ian
