RCU Forums - View Single Post - Some advice please...
Old 11-17-2003 | 01:41 PM
CRFlyer's Avatar
CRFlyer
Default RE: Some advice please...
a 40 might be underpowered. I would recommend a 46 for the lt-40.
The lt-40 can do some basic aerobatics, but it is designed to be stable, not aerobatic. If you build it without any dihedral, you may get a little more aerobatic ability, but at the cost of stability. Another option is to build the wing with less span by removing 1 wing bay from each side. I have seen both these mods done on an lt-40 and it still flew well. However, if you have not flown before, then I would just build it stock. That way you will have an easier plane to fly.
