No room for 1/2" triangle, I even had to cut that away on the top RHS (looking at the front of the plane) to clear the Cowl. anyway i used some real (thick) cyano so its bomb proof now (the old stuff with the powder just fell off when i rubbed it with my fingers)
Im of to the workshop to design the next instalement to my indoor toys, if you like the one you got now malk you are gonna luv this one!! some secret disign aerodynamics that alow a much smaller plane than the original that flys better with more pitch resonse and 720 degree a second roll rate if desired (10 times better in roll than old one) and it can take a good bashing (should make you
Prototype has flown and ali just loves it (recons its the best so far) and to top it off it flys on a standard GWS twin motor £17 and just 3s 340 Li Polys... Cheap as chips
