RCU Forums - View Single Post - How do I install this kill switch?
Old 11-17-2003 | 08:00 PM
SteveW's Avatar
SteveW
My Feedback: (36)
Default RE: How do I install this kill switch?
Hi Juvatwad,
This might help. First, stop thinking of the switch as ON/OFF. Think of it as circuit OPEN (no path to ground, engine runs) & CLOSED (path to ground shorts the magneto, engine stops). Then you can simplify things even more once the switch is installed by labeling the cowl or fuse with "RUN" and "STOP". That way you don't have to do the mental conversion and there is no confusion.
