RCU Forums - View Single Post - Phoenix Atlantis ARF Pattern Plane
Old 11-18-2003 | 09:44 AM
gcflies
Default RE: <span class=
Guess I will have to live with the store not being able to include the manual (since I got it at offered price)
Anyway, I am glad I found this message thread. I am going to use all of the pointers from you guys - especially Richard's pull-pull mod; the nice picture of the servo tray; Simon's point on CofG.
Also good to know that the 3 pieces of balsa and all the other bits don't have proper home.
But alas, I won't be able to set up spoilerons as I am still using the basic Futaba 6 channel 6XA transmitter ...
A couple of questions that I hope you guys could provide me with some more guidance: -
1) Any of you happen to have the url for Phoenix Models? I could not find it in all of the search engines
2) I assume you guys joined the wing permanently into one piece? If so, any one of you reinforced the joint with fibre glass cloth or something?
Simon,
1) How much right thrust are you using? Is 2 degree right too little?
2) Not too sure what do you mean by having the wing mount sealed to prevent fuel leakage. Are you having the wing permanently fixed to the fuselage? Do you mean the hole in the firewall thro' which the fuel lines pass? Pardon my ignorance.
Many thanks in advance!
cheers,
gordon
p.s. I hope to complete this ARF ASAP so that I can move on to the next project - a Laser 200-40!
ID:	75597   Click image for larger version
ID:	75598   Click image for larger version
