Thanks for the input folks. I am not sure exactly how much of these posts are serious and how many are tongue in cheek, but I did go to the garage and find a pane of glass from a discarded storm door. It's still in its frame but I figured it would work for experimenting. The cut edges done on the glass are much cleaner and truer than on anything else I have tried. However, I have only done it with the backing still on (Monokote). I get the impression from a couple of the posts here that some of you are removing the backing and ironing it to the glass before you cut, or was that tongue in cheek. Is the glue still good after ironing it to the glass and then removing it? [
Max
