RCU Forums - View Single Post - What Sort of Blade?
Old 11-18-2003 | 01:53 PM
dr_wogz
Default RE: What Sort of Blade?
Yeah, I guess I forgot to mention, that when you apply color / shape #2 (#3, #4...), you do overlap it (1/8" - 1/4" or larger depending) and iron it in place, low heat. When ironing it to the airframe, take care not to stretch it from a seam, and an apply even tension. also, be careful with the heat gun, as the heat can quickly 'shrink' both halves, and cause the glue to soffen and pull apart. a little 'trim solven't before the final strinking wouldn't be a bad idea!
Gus:
Isn't the idea to get a plane that is very unique?!
If the plane is called 'Ugly stick' why not make teh pklane fit the name!! hahah!!!
The other idea was to have mother earth repel such an ugly thing.. but mother earth, reached up and embraced it's beauty one day..
