RCU Forums - View Single Post - What engine for UcanDo3D
Old 11-18-2003 | 02:21 PM
SunShyne's Avatar
SunShyne
My Feedback: (68)
Default RE: What engine for UcanDo3D
ORIGINAL: clemrick
Any Ideas about putting Tower Hobbies 75 on ucando3d arf from GP. Is the cowl wide enough to accomodate the head on the TH 75? Enough weight to balance that long fuse without having to add lots of lead up front? What about servos, do I need to buy high torque servos?..........................
Thanks for your input,
Clemrick
there is a 50+ thread over in the 3D forum, check it out, LOADS of info!
As far as servos I have Futaba 9202's all around except for the rudder where I have a Hitec 5645mg. Its not required to have digi's but decent servos are a must if you ask me. its a 3d plane so that means the surfaces will get a workout. centering power and hold ability is key here
good luck
