RCU Forums - View Single Post - Has anyone used Gel Coat?
Old 11-18-2003 | 09:38 PM
CoosBayLumber
Default RE: Has anyone used Gel Coat?
Wrong routine in using the materials, in general.
Gel coat is not compatible with epoxy. Gel coat is applied thin to establish a surface on a treated mold. After application, you then begin the usual polyester resin lay-up routine.
Would suggest that you move the comment over to the composites forum, as this has been asked there numerous times.
Wm.
