Cooling problem
Well as far as the ESC gose I was not using one with the 2 packs I used a servo and micro swtch set up. So what you are saying is the whole problem is the 14.4V right? So If I stick with a single pack and spend a small fortune on a new motor I should not have this problem? Thanks for all the help be the way
