rrragmanliam
I use CA hinges and they have worked well for me. I ensure that all surfaces have the square edges removed or beveled. Then I cover them. Take a CA hinge and cut it in half. Next cut the corners off creating a pointed tip on both ends of the CA Hinge. This will help the hinge to slide into the hinge slot. Cut hinge slots with a no. 11 exacto blade. I have hinged surfaces as thin as 1/16" although its tricky. If I have a surface that is 1/16" I normally replace it with one that is 3/32". Have fun.
Hec
