RCU Forums - View Single Post - Slow wobble!
Thread: Slow wobble!
Old 11-19-2003 | 03:04 PM
HenRam's Avatar
HenRam
Default RE: Slow wobble!
Seen the same thing happen on a Rap50V2 due to having the thrust bearings put in wrong... Make sure they are greased and installed correctly, also make sure the damper rubbers are oiled with some silocone grease. Check your linkages too, one might have a hairline crack in it that is giving it the play to make it look like it's wobbling... eventually the whole link will go and so will the heli.
