RE: Engine Questions
Jettstarblue,
I am by far an engine expert. As a matter of fact about all I know how to do is adjust the high speed needle to get the mixture right.
However, I agree with your post. Take hydraulics for example. You have flow control, directional valves, proportional valves, all sorts. Usually the valve stand is located a good distance from the equipment. If you had a delay every time you gave a valve a signal to do something, it would be a mess!
Wings
