RCU Forums - View Single Post - 4*60 ARF wing servo problem
Old 11-19-2003 | 08:54 PM
fredscz
My Feedback: (47)
Default RE: 4*60 ARF wing servo problem
You might try a cotton-ball with a long string in the end of the tube, that you can see, at the root rib, then gently use your shop vac to suck it thru to the servo opening..
If it works you did it right , if it collapses the wing you were not gentle enough.
Fred B
