RE: Engine Questions
Wings:
If you could find the front view of a Tiger Moth, you will see a slot in the front of the cowl for the air inlet. For us just move it over to the front of the cyl.. The outlet is under the cowl at the firewall, about twice the size of the inlet. There is a lip on the bottom of the cowl at the outlet to aid in causing a low pressure area to help draw the air out.
