RCU Forums - View Single Post - Decathlon Engine Recomendations Please
Old 11-20-2003 | 11:59 AM
flying_frog
Default RE: Decathlon Engine Recomendations Please
Thanks for the info.
IronCross...I'm still in the assembly stages but so far it is going together real nice. This is only my 4th plane so I still use instructions quite a bit, but so far so good. Only reall challenge I had was when I cut out the back end of the fuse to insert the horizontal stab and elevator, you're supposed to replace the cut out piece back into the opening. Problem was that the rudder hunge was cut right in that spot so when I cut the wood, the small piece fell apart. I had to make/cut a new piece, glue it, cover it and re-slot it for the hinge. No big deal, but all this was new for me but turned out great.
This ARF came pretty highly recommended by our Club Pres. who has flown this first hand..he loves it. He has also seen people put in .46 size 2-strokes in this and fly just fine. After using 2-strokes and hearing and seeing 4-strokes, there was no going back!
