RCU Forums - View Single Post - Sig Rascal 110 Rudder Servo location ?????
Old 11-20-2003 | 03:00 PM
Meesh's Avatar
Meesh
My Feedback: (135)
Default Sig Rascal 110 Rudder Servo location ?????
I started building my Rascal 110 and noticed that there are two servo cutouts under the tail, one is for the elevator and presumablythe other would be for the rudder, however, the instructions show a pull/pull cable set-up and the guide tubes are installed for the cables.
I will be installing a Saito 150 with Tru Turn spinner and an APC Prop.
Will I need to add tail weight if I use the pull/pull setup????
If so,wouldn't I be better off to just move the rudder to the cutout on the tail? This would add weight to the tail without having to add any additional weight to the plane itself.
Any comments or suggestions will be appreciated.
