Sig Kadet ARF Elevator Hinge Has SNAP! HELP!
Hey All,
So, I'm putting together my first ARF, a Sig Kadet, and everything was going great, until I glued the CA hinges on the elevator. As the glue set, the elevator took on a distinctive snap up or down from the neutral position to a 10 or 15 degree up or down position. The glue was only on the hinge, not the horizontal stab or elevator. There are four hinges across the back of the thing. My question is: Is this okay? Will the hinge loosen up? Will the servo have enough strength to hold the elevator in the neutral position? I'm a little worried, since the CA hinge thing seems pretty permanent. Please help put my mind at ease here... Thanks so much. -Sean "Spool" Mahoney
