RCU Forums - View Single Post - FMS and WinXP and Win98SE
Old 11-20-2003 | 11:38 PM
apteryx's Avatar
apteryx
Default RE: FMS and WinXP and Win98SE
The graphics card based on the nVIDIA chip set appears to be fine, it's just an odd serial/parallel response I get with WinXP to the RC transmitter. Haven't tried it with a printer but after trying a dual boot system with Win98SE and WinXP (MUST BE installed in sequence) and running into more problems with other programs with FAT32 files and WinXP with some that wouldn't load under WinXP on a FTNS HDD ....AND some programs which wouldn't load at all (older stuff) which upset the wife ....I decided stability and ease of use was "job one" and reformatted the drive for FAT32 only and loaded Win98SE. Most all the software seems happy.
FMS runs at 56 Frames per Second in 32 color, 1024x768 mode and looks fine. Since I have nothing to compare it with what do you guys see ? I
might go check out the hobby store because they have a G2 running.
There is a little extra noise on the speaker I need to look into.
