RE: Trinity <span class=
UPDATE
Well - Last night was the first "fun Run" race at the local track, and here are some results that i have gathered.
This engine is just amazing. Set up for about 90-95% power, this engine just screamed. Its sound is soooo smooth, sounds like an F1 car. Max temp recorded with the body on in full race conditions was 231. Avg temp was 214. Smooth, consistant power band, and due to the short stroke bore, alot of power in the high RPM range. The modifcations by Rody increase the low end punch to big block standards. Consistant, reliable idle. No carb loading to speak of. For the entire night, through about 6 tanks of fuel - this engine never hiccuped, and never stalled once.
As for the chassis - amazing as well. Turn in is very predictable, and on power steering is crisp and sure. None of the on power oversteer that the ntc3 exibited. braking was secure and uneventful, hard acceleration was true and straight, with no pull.
This car is much easier to drive at the edge, and has a much tighter turn in and is able to power out of a turn slightly before the apex.
Here was the setup used:
Engine:
RB Concepts Rody Modified V12 3port
HSN 4 1/2
LSN 5 1/8
MSN 1/16 in from flush
.4mm carb opening at idle
6.5mm venturi installed
additional .1mm head shim installed
RB Concepts #7 very cold plug
Odonnell 30% race blend fuel
Clutch:
Serpent Motorsports Centax II
Thrust bearing set at 6.2mm from base
5.2mm from housing
16/19 pinion gears
Chassis:
Droop - 4mm
ride height - 4mm
anti squat - none
sway bars - none
front toe - 1 degrees toe out
rear toe - 1 degrees toe in
camber - 1.5 degrees
castor - 35 degrees
front diff - 25,000
rear diff - 80
40wt oil used in all shocks
Trinity blue springs used.
front one way not installed
TRC Foams 45 front 40 rear
