RCU Forums - View Single Post - U Can Do 3D
Thread: U Can Do 3D
Old 11-22-2003 | 08:57 AM
  #1690
AcroJo's Avatar
AcroJo
Default RE: I & C Tech
Coo, nice job on the plane. Nice and neat. I see you went with the stock push/pull rudder servo setup. I went for the pull/pull. Does a 7 lb. plane need it? I don't know but would like to think it benefits from this setup. On the cowl I went one step further and carved out those little dobbers on either side of the spinner in hopes of some added ventilation. Looks cool too. Also I took 4 of the brass grometts and rubber mounts from the servos and installed them on the cowl mounting screws for vibration. It helps a lot. Joe
ID:	76613   Click image for larger version
