RCU Forums - View Single Post - Gyro Mounting
Thread: Gyro Mounting
Old 05-09-2002 | 09:40 PM
Dyehard
Default Gyro Mounting
When you said you rotated the gyro 180 degrees, do you mean you simply turned it around half a turn or did you turn it top for bottom. Turning it around will not reverse the gyros output, if it doesn't have a reversing switch, you will have to put what was the top on the bottom.
