RCU Forums - View Single Post - Gyro Mounting
Thread: Gyro Mounting
Old 05-11-2002 | 01:19 PM
DavidH
Default Gyro Mounting
GaryC,
Just a thought since you seemed to have checked everything else that would cause the problem.
Are the thrust bearings in the tail in the correct way if it does have thrust bearings?
If it has thrust bearings them being in the wrong way can cause what your problem is when the tail is turning the RPM it would take to hover.
David
