RCU Forums - View Single Post - U Can Do 3D
Thread: U Can Do 3D
Old 11-22-2003 | 08:08 PM
  #1694
SunShyne's Avatar
SunShyne
My Feedback: (68)
Default RE: I & C Tech
ORIGINAL: cumn thru
Coo, nice job on the plane. Nice and neat. I see you went with the stock push/pull rudder servo setup. I went for the pull/pull. Does a 7 lb. plane need it? I don't know but would like to think it benefits from this setup. On the cowl I went one step further and carved out those little dobbers on either side of the spinner in hopes of some added ventilation. Looks cool too. Also I took 4 of the brass grometts and rubber mounts from the servos and installed them on the cowl mounting screws for vibration. It helps a lot. Joe
can you explain your linkages a bit better to me? Do you have links to where you got them? I am leaving smaller planes with standard servos now and dont know too much regarding bigger linkages for heavy duty use etc.
thanks
