RCU Forums - View Single Post - Engine Questions
Old 11-23-2003 | 10:57 AM
  #40
CafeenMan
Default RE: Engine Questions
My credentials? Take a look: [link=http://www.airfieldmodels.com]Airfield Models[/link]
30+ years of running probably 100 different engines on 100's of airplanes. Most of the engines I've owned have not had remote needles. If you're wondering whether or not I don't like remote needles, the answer is I don't care either way. Some of my aircraft did have different engines mounted at different times which is one of the things that made me take notice of the phenomenon in the first place.
But, if an article on the internet says that the wall I painted blue is white even though it's never seen my wall, I guess it's right.
ORIGINAL: jettstarblue
CM,
Just curious, do all your engines have remote NV's?
All engines of any size/fuel type ect. have some lag time after making setting changes. Remote NV's or not.
Have you tried side by side testing of lag time with the same engine with both types of NV?
Not saying you are imagining things, just asking what you are basing your observations on.
The reason this all started was Ed Moorman implied that with a remote NV the "lag time" was increased, which is simply not true, and so I was just trying to clarify things so people wouldn't think if they placed a NV "upstream" the tuning, or tunability would be affected.
As stated I have had some looong distances between NV and carb, with no adverse affects, including "increased lag time".
Yes- I have done side by side tests, just to make sure my extremely long fuel line between the two would work.
Jetts
