RE: FUJI BT-32A engine
I've notived with my 50, that if the magnets are not in the right position before starting to flip the prop, its not starting. The manual shows to have the magnets at an approx. degree(15-20?) before the module so you need to positon the prop on the shaft for your starting style. I also made a mark on the prop shaft to see where the maganets are behind the cowl.
