RCU Forums - View Single Post - CG question Help
Old 11-23-2003 | 06:56 PM
BMatthews's Avatar
BMatthews
Default RE: CG question Help
OK, in the composite pic it's obvious to me that the extra wing area of the red model has too small a stab and a shorter tail moment compared to the dayglo lime green model. That alone may be why you need a more forward CG.
I suggest you look up Tail Volume Coefficient for the horixontal tail volume (there's also a vertical tail volume coefficient for the vertical area) and compare those values. I suspect that if you increase the size of the stab on the red model so the TVC matches then it'll fly better.
Your airfoil looks fine BTW. I can see that it's no more radical than many in use these days and should fly well.
